chevymaher
- Mar 29, 2017
- 2,937
I started in the back. Front was tilted up. The foam worked its way forward and up. Started in the rear because of the outer stringers the inside section is sealed. Except the transom. So I started there. Where as the front is open along the hull for the air to escape.
I just went to the next forward hole when it was to the top. When you put the plug in have something heavy to sit on it. Foam pushes hard. I had 10 lb weights and it was pushing them off. 25 lbs weights were doing the job well tho.
That was another reason I left the tabbing off when i did it. to relieve pressure when the foam expanded. I bought the larger kit. More than I would ever need. I was over filling and allowing it to push out the open tabbing. I didn't get a picture I was to busy cleaning it as it came out. But it was similar to the video if it coming out of the cup holder hole in the side. It was a sight tho all along the deck hull edge Like the blob invading.
I was concerned before I started if i was going to have issues. It is a mess got to just brace for it. But it is easy peasy and fun to do. Once you accept your gonna wire wheel it all to clean it up. Mix pour and giggle and watch.
I did mix and wait to long on one batch. I set the cup down to adjust my glove or something. turned around and it was over the top of the cup all over the deck. Mental note be ready to pour once you stir nothing else matters.
