briangcc
- Jul 10, 2012
- 2,415
Boat: 2017 Chaparral 19H2O Ski & Fish, published weight is ~2600lbs
Motor: 2017 Merc 4.3L 180HP MPI currently with a whopping 8.2 hours on it. Yes this season has been poor weather wise!
Outdrive: 2017 Merc Alpha One, 1.62 gear ratio
Prop: Unknown 4 Blade, 14.25 x 19P
Disclaimer: Yes I am fully aware I am still in my break in period and the below really should have waited a touch.
Had (2) adults, (2) kids - age 5 & 3, and safety gear on board as well as about a full 30Gal of 91 ethanol free gas. Before I go charging into the marina I want to make sure I'm not going nuts or missing something. For reasons I won't get into, we tried briefly running WOT and ended up at 4400RPM with I want to say either 42 or 44MPH. I still had throttle left and nudging it further did not increase RPM or speed. Rev limiter was not going off at the time, all other gauges were normal, no porpoising, outdrive was trimmed out - I want to say the first line above all the way in/down, engine did not sound as if it picked up any additional throttle either.
Selling marina claims boat should come in around 50MPH and I've seen a Youtube video with same boat and a 4.3 190HP TKS top out right around 50MPH so I would think I should be somewhere close to that ball park. The RPM's have me concerned as they seem to be on the low side of the engine operating range. Couple that with the extra throttle available but no increase in speed.
Question: With these new fangled engines, is there some sort of logic built into them that says, Hey dummy - you're under X hours so you can't exceed X RPM's So after let's say 10 hours some logic gets freed up to allow further increases in throttle?
Just curious before I go storming the castle at my selling marina.
Thanks!
Thanks!
