I am wanting to do a re-wire of my 1974 Caravelle. Current setup is a mess, all kinds of random wires of random types (lamp cord, speaker wire, Bare wire) some go places others don't. I didn't wire it this way, previous owner(s) added and deleted items with whatever wire they could find apparently. No Fuses No circuit breakers anywhere!
From the battery I have a hot and ground running forward to power the lights, horn, and gauges there are separate wires for the bilge pump switch. everything is hot as long as the battery hooked up.
The outboard harness runs up separate to the ignition which has nothing wired to the accessory (On) position and 3 wires from the harness hanging loose. Orange(temp), purple(tach), and black(ground).
I am working on a wiring diagram now to clean things up and allow for easy troubleshooting in the future. I plan to add some missing gauges, a radio and some interior lighting in the future as well
1. What should I feed from the Accessory position on the ignition? I would like to have everything dead except the nav/anchor lights and the bilge pump without the key
2. The ground in the outboard harness currently hanging loose, Do I use it to ground the gauges and accessories up front and remove the ground coming forward straight off the battery?
I have attached what I have so far on my drawing. I am using MS excel but converted to pdf so I could attach it. Please let me know if Im on the right track. Thanks in advance!
