I'm struggling to identify the faulty component in a 1990 Evinrude 200hp. I bought the boat in May and the seller tested it in the yard with muffs on and it started right up and ran it for about 10 minutes. The seller had told me that the batteries were not charging and that the regulator/rectifier may be bad. Once I got it home I tested the regulator/rectifier and it tested faulty. I replaced the regulator/rectifier with a new replacement from Sierra. Additionally, I replaced the water pump, both T-stats (6/8 bolts snapped!:mad-new
, the tilt trim unit , disabled the VRO pump and removed the remote oil tank, installed new gapped plugs and rehabbed the entire engine cosmetically.
After all this work was completed the batteries were charged and it was ready to fire up and when I turned the key I had no spark on any cylinder. It's been 3 weeks now (only have the weekends to work on the boat) and I'm still trouble shooting the issue. I went through the SELOC manuals and followed to a T the CDI trouble shooting guide for this (disconnect black/yellow shift wire, yellow regulator/rectifier wires, check all engine grounds, etc.). The first round of trouble shooting indicated to me that the power pack had failed. The DVA connected from the charge coils was ~50v and when disconnected was ~190v. See the table below. All "-" were data points that I did not take. As I continued to trouble shoot in different iterations I realized that there was more data I could capture.
1990 Evinrude 200 HP (Original Parts) 170729 - No Spark Ignition Data |
