I have a problem with the twin DP290's in that I can turn fully to port (approx 2 1/2 turns to port) but can only get 3/4 turns to starboard.
I have checked as much as I can that there is nothing lodged between the drives, and have checked power steering fluid level.
It appeared to happen after we replaced the props in the water (trailered the legs and replaced props)
The drives are definitely not going lock to lock, as I can see the angle of the drives at port is tighter than when turning to starboard.
The feeling of hitting 'full lock' is the same and I can't force it post 3/4 turns, although I haven't actually tried to be too forceful.
Does anyone have any suggestions.?
