Hopefully some of you remember me.
I have a Regal 1999 with the 5.0 Mercruiser EFI (TBI).
I have done so many things to the boat in pursuit of fixing the lack of WOT and power. Such as...
Batteries
MAP Sensor
Distributor Cap and Rotor
Fuel Pump
Oil Pressure Sensor
Heat Sensor
Oil Change
Spark Plugs
And much more.
I got sick of the mechanics not finding the issue & charing me money for it, so I sought out your wisdom but a lot of the things I was asked to do went over my head as I do not have most of the equipment to do even the simplest of things.
After everything that was changed I thought perhaps it is an ignition issue as the timing seemed a bit unstable. Fuel pressure is 30PSI throughout the rev range and under load so again, it must be an ignition issue.
Where the rotor and cap was changed but there appeared to be ignition timing issues, I thought to check the ignition sensor that is inside the distributor and this is what I found:
This looked worse before I took it out, but it is rusty and pretty disgusting looking.
Anyways, I read through the Mercruiser manual which states how to test this and it says that it should have 100 ohmes from the wires. I don't even get a reading. So I tested from the contact points on the PCB board inside and still no reading. A continuity test shows nothing either so I can only assume that this is the reason why my boat doesn't like to rev over 3000 RPM and why the ignition timing seems a bit jumpy and off.
I haven't changed it for a new one to test this out as I have to wait a few days before it arrives but from your experience, does it appear that I have FINALLY found the problem?
Batteries
MAP Sensor
Fuel Pump
Oil Pressure Sensor
Heat Sensor
Oil Change
Spark Plugs
And much more.
