guuben
- Jun 30, 2015
- 35
I got my Barr longblock year 2013 "mercruiser" 3.0 l head back from machine shop - warped head .010 mm.
I assume it was a result of wrong fire timing.
A) But i am very confused about the distribuetor and how its attached in the block (from Barr Marine)
Wherever I see a video or read about how to set timing the distribuetor and the spark plug wires are all attached the same way but not mine!
My spark plug wire for cyl 1 starts at no 2 cyl as in attached picture for mercruiser 3.0.
Firing order of course is right with 1,3,4,2. But i thought that the distribuetor could only be connected with cyl 1 in TDC in one certain position ..as all others except mine have, strange
B) When I connect the two white wires together at the distributor the engine will stop. For a second I can connect them and i get the reading of 0 degrees tdc with stroboscope lamp. I have never connected the third wire beside the white ones....my engine is inboard engine and without interrupting switch.
Maybe the third wire must be connected to batt. + when doing the timing procedure when engine is running (I read about this somewhere) but I have been to afraid to damage electrical components.
C) This too confuses me....when disconnecting the white wires and i make very high rpm,s the timing only goes to about 17-18 degrees tdc!
Idle is about 12 and after that it doesnt change much!
If I understand right a warped head, overheating, damaged valves etc is a sum of to mch tdcb, not because a late firing....right or wrong?
Thanks for your assistance.
(Engine runs today very smooth on idle and response well for rpm,s but in long term I want to avoid another engine crashdown because bad timing.)
