Leaking power steering valve guide / actuator
Hi guys so I got a question. I noticed the other day that my valve guide around my power steering actuator was leaking. So I tightened it up. I also noticed that the power steering pressure line was leaking a little so I tightened that up also. Run the boat for a little bit and the one pressure line blew. So I go back to the line I don't see any leaks but up by the actuator valve guide is loose it moves up and down.
So I tightened it up the best I could fix the line and run it and the line blew again ! Lol
So my question is if the valve guide and maybe the actuator is bad would that cause the lines to blow ?
With that in mind I tired to remove It but it is a pita with little room to work in. Could I disconnect the power steering and still run the boat ?
