JohnnyGuy
- Aug 24, 2017
- 193
I have a 76 15hp Johnson.
As purchased the pull cord is not tight to the lower cowl, it hangs loose approximately 3-4 inches.
We were experiencing intermittent issue with the pinion gear not engaging (or running up the splines of) the starter pulley to engage the flywheel.
When this happened we had noticed that the pinion spring was falling into the groove of the vertical arm of the cup spring. A quick flip of it out of the groove and the gear would then follow the pulley splines and engage the flywheel.
I was wondering if I were to just pull out the starter rope until there was tension and affix the handle at this location if it would likely solve the issue?
Perhaps someone else here has experienced this before though and can provide further comment/direction?
Thanks in advance,
JG
Thanks in advance,
JG
