Rick Russell
- Aug 6, 2011
- 32
Volvo Penta 5.7 Gi-E Engine has been overheating at higher speeds. I did the clear hose test and thought that I had something going on in the outdrive. I replaced the entire cooling system outside of the transom, but decided to isolate the raw water pump and put it under 10 inhg of vacuum before I put the boat in the water. The pump would not hold the vacuum and I could hear air being sucked into the raw water pump through the weep holes.
Do you guys think this could be enough of a leak that it would cause the air entrainment in the system that would lead to overheating?
The raw water pump was replaced 2 years ago, so it would seem odd that it is bad already. I'm going to change out the sealing ring for $15. Thought that would be a good first step before dumping $400 + on a new pump.
