The jet size is going to depend on the engine specs....that is hard to say with out playing with the engine to see how it runs or without an O2 sensor or dyno. I would just stick with what it has and see how it runs. Up at your altitude it is going to want to run a bit leaner. I would see how it runs and check the plugs after your run it for a while. Fat is always better than lean!
Gosh it always looks easy when you see some of these awesome motor guys tear into their projects. Good luck. Looking forward to your progress. Maybe soak the whole component in a lube for easier take apart. IDK?
Speaking of, I soaked my in bearingman's carb cleaner, you can get a 1 gallon bucket with a strainer built in. Works great. I also put mine in the ultrasonic cleaner for a while. Seems like I used both vinigar and simple green....but it has been a while!
I guess you could try it but I would lean towards replacing them if possible. I would for sure make sure you clean anything loose off of them and make sure nothing can fall down into the engine. I would hate to see some rust flake off and damage something.
Thanks for the story, definitely a tough go around since you bought an old one and still had to invest in a new one at the end of the day. At the moment, since i bought the kit and have the carb that came with the boat, ill probably just put it back together and pray that I dont repeat your frustration. although, you could have a good moemnt to say "I TOLD YOU SO!".Here is my carb story and what I started with looked way better then yours......
Really looking forward to getting out on the water.. we had a few days of 70s in Colorado and it was such a tease. Although its now 30 and snowing 1 day later so never quite sure what you'll get out here.Good luck looking forward to some skiing again this summer if we ever get out of this quarantine. I live in NJ its bad here right now
Hopefully, you can make yours work. But, if you do have to replace the carb, Peter Biever on FB is the carb jedi master and he has refirbed Holley 4160s for sale.
