silver_power
- Jul 8, 2009
- 327
Hello. I gave a 350 mag mpi s/n 1A348183 , MY 2010 with about 450hrs. I had some ignition issues but I now solved them. I just made a test run today to be sure that everything is OK but something strange happened. The engine works very good with smooth operation, the temp is steady at about 72oC but as I scrolled to the smarcraft readings, I saw 0 psi water pressure. Obviously I have an issue with my impeller OR with my water pressure sensor. This us something that I can easily find , but my concern is why the engine guardian did not operate. No alarms, no beeps, and 0 psi water pressure!!. The temp was normal and steady. The reading was the same at all the range. The only thing I noticed was about 200-250rpm loss at wot with just a full tunen up engine. (New cap, rotor, wires, plugs all genuine) but this is something I do not concern,...maybe not so good gas. Do you have an idea why is this happening?
Thank you very much.
