1988 Hurricane Restoration
Swimforshore
So after almost a year and a half of procrastination, I'm full speed on a stringer replacement on the family boat. I've reached the point where i could use some advice. I have the engine out and am ready to tear out the decking and engine mounts. I've taken measurements of where the engine mounts are located, but feel like there should be an easier was, anyone have any advice on this. I have an OMC sterndrive. My other snafu is I sawed a whole in the side of the hull while cutting away the decking on the boat "what an idiot I am" any advice on repairing this. I'm going to get some pictures up here in a few.
mickyryan
fixing the hull isn't hard since you will have inside exposed , pics will help , dump omc and look for a mercruiser or volvo replacement since omc are getting harder to find parts for and stay away from yamaha stern drives
Swimforshore
The cut is about 10 inches long and not on a flat surface
Swimforshore
As much as I would love to through a small block in her, not in the budget. Engine has less than 50 hours her and the stern drive is solid. Shes been in the family a long time.
Swimforshore
Is photobucket still the preferred pictue posting method? I can't seem to find the thread for picture posting.
chevymaher
No it isn't Postimage.org is what i use if i have to now. But if you reduce image size this site will just accept them.
Swimforshore
I got some more teardown done last night. I'm starting to acquire supplies for the build. Any opinions on what weight of CSM I should use for wrapping the stringers?
chevymaher
1.5 oz and 1708 biaxle cloth is the recommended approach. In the Teachings of the Master Woodenglass. His signature has recommended layups.
