archbuilder
- Sep 12, 2009
- 5,697
That is always frustrating! Hang in there!
Lol! maybe! Tell me does this happen to you too? You research something for a while. Example; Origo two burner recessed alcohol stove,
Because it seems like the perfect solution. And then when the time comes to pull the trigger........Poof! Gone! Discontinued! NLA! Or you research wood finishing products and your search leads you to XiM products Mar-X-ite wood sealer and adhesion promoter and when the time comes to start the wood finish portion of the project. Yep! Poof! Gone! Discontinued! NLA! Lol! What say you Brotha?
Cheers....................Todd
It used to be the same as the far end all the way along.
This is is kind of looking left from the previous picture, looking down C dock. They've gotten the wiring run but no pedestals yet. So I've run a 100' extension cord down the the main panel when I could do it without getting in the workers way
The only thing I can think of is maybe some kind of dinghy or a kayak mount. Not jazzed about the big hole in the middle but don't want to take it all apart to fix it.
I got the four mounting rails off.
One of them was broken. Another was split because of a plain steel lag screw that held a brace bracket. So I'll need to remake at least a couple of those. And I think all of the braces. They are there but had never been fitted or installed. They are made of red oak I think and have some splits and checking. I've got to get some Mahogany (probably Khaya or Sapele) for some other parts so I'll re-do those as well.
This is why you only use proper bronze fasteners in a boat kids!
where did you go i am restoring almost the same owens boatNice job on the throne! Frisky little critters you have there. Good to see you back.
