I preferred the whack to the prying.
Any connection I ever had problems removing responded better with impact than brute force.....especially SS bolts screwed into marine aluminum castings.....that you want to remove without twisting the heads off.
Lubriplate (brand) grease, available at WW and a lot of auto parts stores, the white stuff in the black and silver can, has been a marine grade lube well before the 50+ years I have been boating and used it. Stays in place and is water proof.  Or Mercury/Quicksilver has their blue black grease in a tube that is excellent....when you can find it and if you can find an adapter too, fits the little grease nipple (not zerk) on your engine pivot shaft...the one just aft of the clamp bracket center.
