Hey everyone. Read through the current posts. Just wanting to confirm I've diagnosed correctly before spending more money.
I just bought an '06 Chaparral with the Merc 496 Mag. When water testing, it beeped once at about 2-3k RPM and then throttled back on it's own. Did it a couple more times. I googled, found the IAC issues, and then the dealer replaced the foam filter and said they cleared IAC codes (filter was pretty dirty).
Knowing the IAC was cheap to replace, I bought the boat and replaced the IAC when the problem resurfaced for me. That didn't fix the issue (even with an OEM IAC).
Now I'm thinking it's probably the PCM driver.
It doesn't do this constantly. I let the boat warm up, take it out, and then it does it a small handful of times when I first try and cruise around between 1500 and 3k RPM. It then goes away on it's own, coming back only after letting the boat sit at anchor for an hour or more.
Is there anything else I should look into before I tear out the PCM to have it diagnosed and repaired? I don't plan to just buy a new one.
Thanks for the guidance!
