TBarCYa
- Apr 13, 2005
- 781
I went into today with a plan to remove the broken dipstick tube from my 08 3.0L. I had some 5/16"allthread and was going to thread it into the broken tube then use it as a makeshift slide hammer to pull it out. Worked wonderfully except that there´s very little of the 5/16" section of the tube left so the allthread pulled out. On to the backup plan... 7mm allthread for the smaller section except that 7mm allthread is impossible to find. I have a 7mm bolt but no way to grip it and after going through the 1"of 5/16 thatś left, thereś not much to thread into the tube.
So... What are my options? I can look online and order 7mm althread and wait for it to come in... Thatś what Iḿ leaning towards because I should be able to thread it 6"or more into the tube so I know itĺl grip. I could run a tap in it but thereś no shoulder on the tap to even get some leverage on plus applying pressure to the tap will likely break it, leaving me with no way to get the tube out. I could try an adhesive (epoxy or jb weld or something) but the tube is oily so its unlikely to stick... Any suggestions other than dropping the pan?
Thanks.
Thanks.
