New problem - Gen 2 shift shaft change
So, my previous thread I discussed doing the lower unit shift shaft change on port side (Counter Rotation). Well, I did it, all was good. Boat shifted fine non-running, and on on muffs. Put her in the water, at marina mooring tested shifting both engines several times, all good, same at gas dock. When I got to my mooring, as I was maneuvering her, I lost the port motor, started her back up, she turned over right away, but as I was shifting she wasn't responding right when i realize i have no reverse. She is stuck in forward. There is a little movement when I shift to neutral, enough that when I turn engine off she slips out of gear, but that is it - she stays in gear once she is engaged until turned off.
I am having her pulled this weekend, hopefully to look at. The shift shaft is now stuck (i got into very cold water to make sure), or at least I assume as the cable is also brand new. As it is costly to have her pulled (32'), any insights would be appreciated. 2 things I am not sure of:
On the old shaft was a small sleeve that is also in diagrams. On the old shaft, it just sat on top of the new seal housing, so that is where i put it.
Also, it was windy, first day out, and i was shifting a bit quickly to get in place - could an overly fast shift from fwd to reverse, or vice versa, cause a jam? And if so, any suggestion on getting it undone while in water?
Also, props are SS if it matters.
Any insights on what to look for would be appreciated. I am going to just pull the lower to isolate the shift assembly just in case it is something with the cable or the shifter in the outdrive, but if anyone can give me any insights on what else to look for or do, I'd appreciate it.
I am also going to talk to the marina about cost of a rebuild just in case.
Thanks.
