I have a 1999 Mercury 200 EFI and it seems to run fine and pushes my 20ft glass boat to 50mph, but the idle seems to be a bit rough and the motor shakes at low RPM's. I have checked the compression and it is 130 on all cylinders,
I replaced the plugs, and checked the wires and found no damage and virtually no resistance. I'm getting spark at all cylinders.
Not sure what else to check, or if these is even an issue as I have seen others say that's just how they run.
Here's a video of the idle
https://youtu.be/I0GXEPpy4ew
