TBarCYa
- Apr 13, 2005
- 781
I know there are a ton of "cranks but won't start" threads but this one has a story just in case it changes the diagnosis.
This morning when I went to start the engine, I pushed the shift bypass and pushed the throttle to full (like I always do) but it got stuck. I was messing with the carburetor linkage as it seemed like it might have gotten stuck there and my wife was able to get the throttle back to neutral. I didn't actually do anything but wiggle the linkage that I believe is for the accelerator pump.
We made the 20 minute putt from the lift to home (we don't have a lift so we keep it on someone else's) and everything seemed fine. I turned it off and about 40 minutes later tried to start it back up to get on our way for the day. It was a little slow to crank but started and seemed to run fine.
While idling out of the canal, I noticed that the battery gauge was reading about 13v which is low for when it's running. Once we got up on plane, the voltage came up to almost normal but I noticed at times it would drop to 13 then rise back up. I kept an eye on it so I knew that even if it wasn't charging, we'd have enough battery to get it started and back home. The voltage never dropped below 12v.
On the way, there were two instances where the engine sounded like it backfired. That's the first time in 10 years it's ever done that so at this point I knew something was up... Just not sure what. We were down on power but almost to the island where we were spending the day so I anchored and we hung out for the day.
When it was time to leave, the engine was slow to crank and didn't even try to fire. I thought I may have flooded it because I did the usual advance the throttle to full and then back to neutral before starting. I waited a few minutes to try again and it was now completely dead. I had power to the stereo and the VHF, the lights and the GPS... Just nothing to the gauges or the key.
I tried to bypass the key and nothing. I bypassed the tether/kill switch and nothing. We got a tow back home and after reconnecting the kill switch and key and a bunch of poking around with the test light, I found that the 50A breaker on top of the engine is apparently dead and powers the key. I bypassed it to test and now the gauges work and the engine will crank. But not start.
I know the breaker is bad because pushing the reset button didn't connect the terminals, even when tested with a meter and the battery disconnected. I'm guessing that it just died open which I guess is better than dying closed.
I pulled the distributor cap (which along with the wires is original) and it looks brand new inside. There's no corrosion or anything that's burned. The button in the cap springs back smoothly and all of the terminals looks clean. Here's where it gets weird.... When I pulled the coil wire off the distributor to test for spark, there was spark and it acted like it wanted to try to start. It tried more than with the wire connected but I couldn't keep the gap close enough while cranking to see if it would actually start.
So that's where I am. Tomorrow I'm going to try to locate a new breaker and a cap/rotor/wires but because it tries to start with the coil wire not connected but arcing to the terminal I don't know if that points to something that I'm overlooking. Maybe it's timing and the wire being off is delaying the spark just enough to let it try to start? I don't know but the distributor hasn't moved and I tried to turn it and couldn't.
The DVM tells me I have 12.8V at the battery and now the engine cranks normally. I'm going to put the charger on it overnight just in case. One question I have is does the ignition module (under the rotor under the cap) just deal with spark advance since it's a straightforward connection from the coil to the plugs?
Thanks for sticking around this long... Any suggestions for what else to try are immensely appreciated.
