So I picked up this fabulous little boat recently that I'm working on repairing, knowing there were engine issues. So the outboard has ~30psi of compression in the upper cylinder and about 90psi in the lower, the head gasket shows rather obviously why that is.. but when I took it apart there is this weird scoring on the top and bottom of the lower piston. Now luckily for me that part doesn't touch the cylinder wall but has been making contact with the head, as can be seen in the pictures.
Now I was wondering if I could just file the rough parts of that down or if I really should be replacing the piston/head.
I also was wondering if anyone knew what might have caused that to happen
Thanks
Thanks
