Big dawg 23
- Jun 13, 2018
- 7
I inherited a boat from father that passed away. It is a 2001 Glastron GX 185 SF. It has Volvo Penta 4.3GL.
The engine plate is the following
4.3GL PEFS
4012029634
3869053
First the boat has been in storage for 3 years. With a new battery in the engine cranks and tries to fire. However, when I release the key it stops. There is spark. I have power going in and out of the fuel pump. I have even hooked up a separate fuel tank to eliminate the old fuel. Removed the fuel line at the carb and cranked it getting about 8-12 oz of gas out. I have checked all fuses and they are good(tested via OHM on Multimeter to confirm). After reading many threads I am thinking there is an issue with the lanyard kill switch that might be grounding it out. I have twisted the wires together and still have the same issue.
Am I correct in suspecting something is grounding out engine causing it to just cranking but not run?
Thanks fo your help.
4.3GL PEFS
4012029634
3869053
