Hey folks, hope you can help. I recently purchased a Gheenoe 15'4 (Highsider) that's powered by a Nissan 8 hp 4 stroke (NSF8a3). The stock prop had already been replaced with a Solas 3 blade 8.5x7 aluminum prop before I purchased it. The motor runs great, I haven't had any issues... fires up on first or second pull, idles within range (900 rpm) and seems to run a like a champ. My only issue is that the rpm's are topping out at around 3000 at WOT. Speed is right at 14 mph with just me (so less than 400 lbs total weight with boat, motor, me and gear). According to the specs, this motor should be running between 5 and 6000 at WOT. The motor is sitting on the transom w/ no jackplate, risers etc. Anybody have any ideas on why I'm not seeing higher rpms or any experience with these 4 strokes?
