Howdy All - I really appreciate your help on this one because its been driving me nuts. Backstory here is that I'm new to being a father and currently a veterinary student. Life has been busy. But now I have the summer off and a little more cash in my pocket and I'd like to get this engine problem solved. I'm not really into throwing money at parts so anyway I can "test" something before calling it quits would be preferred.
I've taken it out probably 2 dozen times. It has never once failed to start on me and never once died (maybe occasionally at low throttle when docking - still need to adjust that.)
Pretty consistently, what happens is that it cranks right up (no problem). I let it warm up on the trailer for a good 3-5 minutes. I'm in Texas so its HOT anyway. And then when I take off from the dock and ask for WOT, it probably goes to about half its capable RPM range and just hangs out there (during that time my throttle arm i full forward). Can't get it up on a plane, no nothing.
Anyway, after about 5 min - and sometimes I'll try to wind her up in neutral and turn it off and back on again (doesn't seem to help), there will be like the sound of a hiccup and then instantly she runs like a swiss watch - usually for the entire day. No problems whatsoever... Recently I went out and did this same thing but this time I asked for WOT and it gave me half.... so I was waiting waiting.. then it revved way up but sat dead in the water, then when I backed it and asked for WOT it gave me half again and started to propel me then got up on a plane... Once it has done this I can usually get on and off a plane fairly easily... I just don't get it. I'm at a loss. Any Ideas?
Since I've had this issue I've done new plugs and when I first bought it checked compression (about 1.5 years ago now) and they were all within a couple PSI of each other.
Thanks!
Thanks!
