weezzell_5400
- Jul 25, 2012
- 50
I got a boat that needed a new motor ....I got said motor as a long block from a dealer ...old motor was a 5.0 mercruiser ..new motor is a 5.7 mercruiser ....now ...the old motor has the coolant bypass hole for the water pump ...so there are 3 holes that water flows through ....the new block does not have said hole for the bypass ....is this a problem ....or can I just put some rtv on the gasket surfaces and bolt it up like normal ...or do I need a differant water pump all together
