I just replaced the head gasket on my 4.3. Thundervolt 4. Ran great before the head gasket. I put the engine back in the boat and started it up. Runs great at idle but when I start to add power it starts to break up and runs bad after about 1800 rpm's. This was done in the driveway and not under load. I've had numerous people look at it and they agreed it sounds electrical. Like the system is shorting itself out somewhere. I had the distributer out and re-aligned the rotor to point at cylinder 1 TDC in the distributer cap when I reinstalled everything. I set the timing at 8 degrees BTDC at idle. I replaced plugs, plug wires, distributer, coil and cleaned the carb. I took the gray wire off the tach and still had the same issue. I disabled the interrupter switch and there was no change. Compression on all cylinders was 180. When I replaced the coil, I took a reading at both the negative and positive side of the coil. With the key in the on position I had 12.3 volts on both sides. Is that normal? The (- ) grey side was 12.3 and the (+) purple side were both 12.3. I tested the coils (old one and new one) and they were both within limits.
If the ICM (back of distributer) fails does it fail all together and get no spark? Can there be a partial failure?
If the ignition sensor (inside distributer) fails will it work partially and get no or intermittent spark?
I've read a lot of posts and the posts that were close to my issue seemed to never get resolved or there was never a follow up with the solution. Thanks.
Glenn
Glenn
