-Cranks...
-Starts...
-Idles... for 1-10secs dies instantly randomly, idle at around 1100rpms cowl off, muffs on
give it some throttle, higher rpms, idles fine, 1500rpms
will do it for about 10mins-15mins and then wont want to crank over, batteries will be dead, ran
for the longest it has, about a minute at around 1500rpms, then slow crank/wouldnt start after
about 5 more times of it starting/dying within 10secs
last year_______
last year it would have a real hard time starting, when it started it would idle but roughly, id
have to start it and throw it in forward/reverse almost instantly to keep it running, if i tried
to put it in gear it would die
-Its getting gas 100% ive checked every line
-Cleaned carbs, checked carbs, theyre fine, nothing clogged or anything,they where clean as new when
took them apart
-All plugs have spark
-Took flywheel off, sandpaper/cleaned rust off stator/flywheel same thing happens afterwards..
what could cause this?
-Starts...
last year_______
took them apart
