Took this project boat out last weekend to play for a couple days and run a tank of fuel through it. I bought it and it hadn't run for 3 years. I was able to use it to pull skiers and a tube but it definitely has some issues.
The start sequence goes like this, throttle all the way forward, choke, and crank. It will pop, release the choke and grind a bit until it fires up. It will NOT idle in the neutral position. You have to keep it throttled.
It won't idle in gear or in between reverse/forward, you have to go to neutral safety and keep it throttled. You can't low speed move (like in loading on the trailer) it just dies.
As I said, it runs pretty well on acceleration, but does have a bit of a stumble. It clears up and accelerates fine and runs perfect at speed.
I brought it home and pulled the carbs off, fully expecting to find all sorts of gunk but they were actually pretty clean. I used aerosol carb clean and blew out all passages, check the needle and seats for wear, checked the idle/air needles for wear, adjusted the floats and put them back on. I synchronized the carbs, adjusted the throttle plate/eccentric, and set the air/fuel needles to 1 1/8 turns out. Fired it up and still won't idle. The bottom carb is running fuel out the throat and the little brass bleed hole on the port side of the carb body, just behind the fuel line tee. I rechecked the float and it is fine. The top carb seems fine.
What do I have going on here? Is my fuel pump overcoming the needle and seat, or is there an internal problem with this carb? TIA for any help. I have watched all the videos I can find and haven't seen this issue.
