Ayuh,..... What's the issue yer tryin' to fix,..??
I ask, 'cause it's rarely to never the coil,.......
Ayuh,..... You've got a Carb problem, not the ignition,.....
Would a carb rebuild fix it or what do you recommend?
Ayuh,..... I imagine a good rebuild, 'n tune oughta cure the issue,.....
Sounds like it's runnin' way rich,.....
There are several carb rebuild videos on Youtube.Thanks. Ive never taken a carb apart,
I’m trying to figure out if I need to replace.
Ayuh,..... If the motor was runnin', there's nothin' wrong with yer coil,.....
Have ya rebuilt the carb,..??
