Railroader12
- Aug 1, 2018
- 46
I posted earlier, realized it was in the wrong section, hoping I get some help over here.
New to me last week 2006 Tahoe 228 22.5' deck boat, 5.0 Merc TKS Im nearly positive its thunderbolt V. Engine bounces off limiter in neutral will NOT rev past 4k boating. Went from a 15.25x21" prop, to a 14.5x19" to a 14.5x17 yesterday and GPS speed doesent change a single MPH (31 max) nor does the Tach show much difference in RPMs between the 3(maybe 50RPM). The only difference is it becomes easier to plane on the 19 and 17". Engine runs Great and very smooth, I cant hear any misses or hicups, only thing to note is it smells pretty rich at idle..It just has no top end whatsoever. Tahoe claims the boat has a top speed of 46? with a 14.5x19" prop, Im not even in the same galaxy...
I removed plugs and few were BLACK and they were all gapped to .060, book calls for .045 so I changed them and gapped accordingly, base timing was 4 I set it to 10 as book states in base mode with the purp/wht wire grounded, I then re-set the idle speed and idle mixture screw to specs and replaced the cap, rotor and coil since there was some oil leaking in the cap and to rule any of that out. I ran a cold compression test and all 8 show 160-165 so were good there. Block and heads were replaced recently and they swapped everything else over from the old block. Think the old block had cracked due to sitting in a marina unwinterized for a cpl years. Has a new fuel filter/water seperator and fuel lines and the tank is clean with good fuel. All plug wires go to the right plug.
I read about merc's "Guardian" or limp mode, thought maybe that could be it.....after HOURS of digging I cant find a single thing relating to either for the TKS, TBV ignition. Alarm doesent sound when key is turned so there is obviously something not hooked up correctly there or the alarm is bad, but, I dont think this engine had the limp mode anyway so there went that. All gauges work correctly on the dash, slightly high oil psi but Im not concerned with it, temp stays where it needs to be. This engine has no knock sensor to retard timing either.
So? What do you guys think? Rather not unload gobs of money to figure this out, but not sure which direction to head next, I was sure the new ignition items were going to solve the issue....not so lucky.
