harringtondav
- May 26, 2018
- 2,510
So I'm wasting my Sat. afternoon time pipe dreaming, and probably will be wasting some of your time too.
I'm wondering if my '96 4.3LX could be converted from it's Thunderbolt IV to a V. Assuming the graybeards don't answer "Nope", I have questions.
First mine is working fine, and hopefully will continue. But if it dies, I see there is only a few $$ between a replacement IV ICM and the V that is used on the '98 -on 4.3LH Gen+. In fact the ICMs look the same, except the IV includes a jumper harness (apparently worth $25).
Since I'd sunk the big $$ into the ICM, I might want to go to the full Thunderbolt V Knock Sensor system. It's timing advance curve looks like it could provide advantages.
So:
1) My manual shows the V's knock control module piggybacked on the ICU, but I can't find any knock sensor p/n's. Is it separate, or built into the V's ICM? If so, what is the p/n?
2) Integrating the wiring could be my show stopper. Online parts manuals are vague with the V's connector. This makes integrating the knock control module a big question. Any thoughts?
2) My manual also shows the knock sensor in the starboard block, in front of the starter. Does my LX have this port plugged? Is it in the water jackets or oil pressure gallery? My manual shows a common knock module signal wire with the ICU, but doesn't show the knock sensor input?
Whew, and thanks.
So:
Whew, and thanks.
