nate_gig_harbor
- Aug 13, 2018
- 5
2001 Bayliner Capri 192 with a new (in 2010) mercrusier 4.3 with the Alpha One outdrive
3 weeks ago went to raise the motor and nothing. Up/Trailer switch not working, down direction was 'clicking' intermittently.
Checked the pump motor, solenoids and things looked like they needed a refresh so I replaced both the up and down solenoids, cleaned all connections with sandpaper, replaced the 20 amp fuse and checked the voltages and continuity of all solenoids and switches. Since then now none of the trim switches are working, not even the trailer button.
- Can manually jump solenoids and raise/lower motor. Could do this before and after replacing both solenoids.
- Pulled wiring harness connector and tested leads and am getting continuity on switch (using Ohm meter) for down direction and trailer switch, no continuity on up switch at all.
- no more clicking on the down direction.
Feels like this is a trim limit switch problem but would that have cause the 'down' switch to fail as well? Or if the up/down switch on my control unit went bad, as indicated by the lack of continuity on the 'up' switch, would that cause 'down' and the trailer button to stop working as well?
