I've got a cold start issue that started recently. After a bit of research it seems it's fairly common. After a week or so sitting idle in my garage the motor takes a while to start. I'm not seeing a good stream of gas while priming the carb. The boat will eventually start but it takes of bit of coaxing.
If I park it and go right back out the next day it starts and runs like brand new.
Regardless the boat runs very well once started, idling, top end, etc.
I saw something where the carb bowl is emptying or draining leaving a dry carb bowl for the next start up.
Will a carb rebuild fix this? Any idea where the fuel is draining?
Thanks for any help..
