Hi All,
I want to start by saying i've looked up and down this form (and others) at previous posts regarding the MerCruiser alarm system. This forum has provided me with a TON of valuable info in the past.
Specs
Boat: 2005 Bayliner 219 SD
Engine: 5.0L MerCruiser Carb
Engine Serial: 0W044469
Outdrive: Alpha 1 Gen 2
Summary of issue
It all started as random beeps of the alarm, typically when getting up to speed. Alarm would sound, few beeps then constant for 30sec-few minutes, then off for a few minutes. (no pattern) Backing down on throttle slightly would sometimes cause it to turn off but sometimes would also sound at low RPM. All gauges seem to be normal. Temp normal. Oil Pressure normal. Gear lube full.
- Impeller / water pump was replaced this summer
- Thermostat replaced
- Both temp sensors replaced that were located on thermostat housing
- Gear lube & sensor replaced
* The only sensor i have not yet replaced is the oil pressure sensor.
Today after reading multiple posts, I tried, as suggested, disconnecting each sensor one at a time until the alarm went off.
The constant alarm never turned off.
I thought for sure that the Oil pressure sensor was the culprit, however i'm baffled as to why the alarm remains constant when all sensors are disconnected. Could this be a bad ground? Bad alarm?
To clarify, the alarm initiates when the key is turned to "on" and remains constant even while running all the way to temp.
There are no signs of overheating, motor runs strong.
Hoping someone on here can point me in the right direction on what / how to troubleshoot next. I plan on replacing the Oil Pressure sensor next, but its a tight squeeze and figured I would troubleshoot first before replacing that one. Thought for sure disconnecting all sensors would point to the oil pressure sensor.
Thank you!
Specs
Summary of issue
Thank you!
