When you do the conversion you normally remove the harmonic balancer, remove the magnets if damaged and remove the 4 allen head bolts and remove the stator. The output wire is connected to the same post that has the battery cable
Removing the stator was not an option I wanted to tackle. The engine would need to be pulled to remove the harmonic balancer. I just taped of leads for now.
