MilleniumFalcon
- Aug 9, 2018
- 14
I have a 1989 mercruiser 5.0 serial number B903262. After a season of losing power, hard starts, rough idle, engine stalls, and black smoke I decided to pull the carb and rebuild it. This is the first time I’ve done this and the kit seemed pretty simple. Now with the carb back on, I can’t get it to start without having the choke plate propped open and it will die if the plate closes. I’ve replaced spark plugs and wires, fuel lines, fuel pump. The carb was definitely a mess when I pulled it apart. The boat ran fine most of the season but I think I had a wire go bad to a spark plug and that’s when I decided to look at the carb. Adjusting the idle mixture screw does nothing but adjusting the fast idle so the throttle is open more seems to help it start and run.
