06 GT Driver side front seat, power seat doesn't work at times
ezbtr
Forwards works more than back,(at times OK) possibly bad switch under seat???
No motor sound, I'm just getting off an accident/on walker, but I will check switch, has been doing it off and on for 6 ish months, it(same switch) does work for back and forth tilt though
82rude
First thing id do is look under seat,unplug each plugin one by one and spray with cleaner and lube.
Redfred1
Had a similar situation with the Door Lock switch.; posted it here back in March. Cure was a eyedropper with alcohol. It worked for me!
