You are looking to align the single line across the harmonic balancer with the notch on the timing tab that corresponds with 8* BTDC. Keep in mind you should:
first check and adjust dwell because dwell affects timing
make sure your idle speed is correct (600 rpm) because you don't want any spark advance happening when you set base timing. If you have the OE distributor it should be a Prestolite points distributor with centrifugal advance.
How do i check the dwell, and is there a way to verify my rpm is reading correctly? I dont have a tach.
you borrow a dwell meter and a tach then.
they loan those tools at Autozone
Please don't take this the wrong way but anyone trying to 'tune' an old school engine without a tach/dwell meter and a timing light, ahh....you're not really serious about doing it the right way. Do it right or pay to get it done.
I got my first tach/dwell meter and a timing light....in 1975...doing my family's and friends' cars....come on, the tools are not expensive...compared to ruining your engine doing it wrong/
Either perform the maintenance correctly or pay someone to do it.
There are no shortcuts
Okay ill do it right just need to get tools in. Whats your opinion on if a trip this weekend is safe while waiting to complete maintaince. Its at 4 degrees i need 8 degrees?
Heres a photo of under my distributor. How do i set the dwell angle? Is the point gap set aready after i set dwell angle or is that separate? After dwells set do timing right? Do i just hook up tool and read timing and turn distributor as needed or do i need to unplug or block anything on distributor before hand? Thanks
if your dwell is correct, and your just at 4 degrees, then your simply down on power
you hook the dwell meter up to verify the dwell. adjusting the gap is what adjusts the dwell. if you didnt file the points, you didnt really set the gap
I normally read/adjust while cranking with the cap off and plugs out. however thats me. been doing it for 40 years that way
however your pic shows that you have an electronic conversion done, so you no longer have points and the dwell is fixed. you only need to set the timing
read links 17, 18, 19 for further understanding of points https://forums.iboats.com/forum/engi...ion-for-diyers
8 is fine and yeah you don't have to worry about dwell, that Mallory is doing it for you. Now one question, were the changes made to make the OMC ESA work with the electronic ignition? Normally you'd have to use a different ESA module or wire it like a Merc Alpha. Before you put this boat in the water, trigger the load lever on the shift linkage which will activate the interrupt switch, the engine RPM should lower from about 600 down to 450 or so (it will seem like its barely running). If this does stumble the engine, then you have to deal with this or you may not be able to shift your Cobra drive from in-gear to neutral while on the water.
