Hi folks - just bought my first boat and am looking to get it into reliable working order. The forums here have been incredibly helpful thus far, so big thanks to all the contributors.
I picked up a cheap old boat as I am happy to work on it myself and would rather make my learning mistakes on something of low value, and sure enough it I've already done so.
1994 merc 4.3L w/ Alpha gen 2.
Prior to first time out I went ahead and changed fluids, impeller, plugs, wires, rotor, etc. with the thought I should just assume this hasn't been done. I didn't dig any further before the first trip out.
Took it out and it overheated, both at low and high rpms. I'm pretty sure I stupidly didn't get the water tube lined up. It only got up to about 220F so I doubt I did any serious damage, but I'll be doing a compression test shortly.
Question 1: Took the drive apart for a look and found milky drive oil. Could this have been caused by a water tube not connected and thus water pressure blowing water past the shaft seal?
Question 2: I went ahead and took the upper unit off for a better inspection. Gears look ok, but the u-joints and double cardan assembly are all rusted. There is no water in the bellows so I am wondering if it previously leaked and was replaced. Any advice on what I should check/do? Just lube it up and put back together, or replace the bellows as a precaution?
Sorry for the long post, and thanks in advance!
-Kris
-Kris
