I have a 2006 Rinker Captiva 226 with a 5.0 Mercruiser that bought from a family member whos husband recently passed away. When he bought the boat it had a burned up outdrive which he replaced with a remanufactured unit. The second outdrive went bad and had to be replaced. He only took the boat out twice after replacing it with the third one. Since he passed away and I got the boat, I've been in the water for several months now with zero problems until this weekend and now the third outdrive has gone out in it. After removing the drain plug from the lower unit, I found about 3/4" of metal shavings on the magnet. I can't help to wonder if maybe somebody installed an outdrive with the wrong gear ratio in it, but not only do I not know what the gear ratio should be for this boat, I also can't help but wonder if maybe there's something else causing one outdrive after the other to destroy gears. Any insight would welcomed!!
Jimmy
Jimmy
