With my first season of owning a boat coming to an end I’m going to be pulling the outdrive on my alpha1 gen1 for the first time and replace the bellows, gimbal bearing and impeller. Not sure when they were last done so i might as well do it. I will also be inspecting the u joints and replacing if needed. I’m just looking for confirmation on part numbers before i order them to make sure i get the right parts to do the job before i start. [h=1]Sierra 18-3320 Water Pump Kit for Mercruiser Stern Drive[/h] [h=1]Sierra MerCruiser Alpha Gen 1 R MR Bellows Seal / Repair Kit 30-803097T1 (Greasable)[/h] I’m going to order the bellows tool as well unless you guys don’t think it’s necessary since most of you have been down this road before. Anything else i should have on hand or think about replacing before i pull the drive? Thanks
