siavoshdana
- Sep 16, 2018
- 3
I have a strange problem here on a late 70s Mercruiser 188 with a Ford 302 on it.
- I have recently replaced the distributor to a HEI distributor. New plugs, new wires.
- She starts right up, idles smoothly, revs up to 5000 no load
- When I put in gear GOING FORWARD, she has no problems, no stalling, no backfiring. Slowly give gas up to ~1500rpm and she has no issues. As soon as I try to go above 1500, she starts backfiring into the carb and as soon as I go back to 1500rpm she calms down.
- I put in gear GOING BACKWARDS, she has no issues and revs up to 5000.
here are my humble thoughts:
- If I had a timing issue, it would be there load or no load, forward or backward
- If fuel mixture was too lean, i should get the same issue going backwards.
I'd really appreciate it if you could let me know your thoughts.
