- Mar 8, 2009
- 43,336
More then one sender on a sigal outlet with a Tee will make no difference in the reading. Your readings makes me think the sender works in reverse (low resistance for low, and high resistance for high) then the North American standard. The European standard use the reverse.
So far as the sender, this is a difference between what you all came up with and me. I believe the oil sender is 881879T11 not 8M6000626
If you have analog trim senders, they will not work with smartcraft without a analog to digital converter. I installed a digital to analog converter trying to get it to work the other way, and mine still does not work. Longer story
In short, the digital trim limit/gauge sender is all in one and mounts on only one side of the drive. Smartcraft reads the data and controls both. With SC, as in my case, gauge doesn't work but trim does, but also does not have a limit
