harringtondav
- May 26, 2018
- 2,476
Just took the outdrive off and found oil in the bellows
I looked at your pics. The oil in the bellows is from a leaking gear yoke seal. That yoke is the one closest to the drive in your third pic. Your gimbal brg. looked clean and rust free in the first pic. Although your Unis and yokes look a little rusty.
Gear lube is cheap compared to changing that gear yoke seal, unless you have the special spanner to remove the castle lock nut. Just keep it topped off, and check for water or milky lube in the drive. Give the gimbal brg. enough pumps of grease to see the clean stuff ooze.
Rust is from water entry. That may have rusted the gear yoke's sealing surface, causing the oil leak. That big, square cross section O ring seal inside the bell hsg. (which appears missing), plus the bell hsg. to O/D joint gasket can allow water entry if worn. Maybe start with those two, included in any seal kit. If you're lucky, that will keep the water out of this area. If that doesn't dry things up, time for a new drive shaft bellows.
I live mostly on the Merc. stern drive forum. So this is get-by advice. If you out drive gives you more trouble, take it to that team of pros.
