1990 4.3 Century 2000 - Floor,Transom,Stringer,Upholstery Project
Mechanicalmike08
Coming along nicely, you can try a hair dryer on the front cushions to tighten up the fabric a bit just don't sit in one spot to long. A day in the hot sun will help too.
AShipShow
The rear engine mount has a fiber washer, a spring, a sleeve and a metal washer. I forgot where what goes. I know the fiber washer goes ontop of the transom assembly mount, then I think the spring goes inside the hole of the transom assembly. then the engine mount with the sleeve and the washer on top
Sounds like you got it... spring washer goes inside the fiber washer, then the long bolts go thru mounts with large washer on top of the spacer... make sure your threads are clean and start the bolts by hand... you don't wanna cross thread them.
Chris51280
Ensign
Thanks.
Chris51280
Ensign
Installed new trim sensors and bellows. I forgot ho much of a pain they are. My fingers hurt. I wonder who the poor guy at the factory must have felt doing this every day
Chris51280
Ensign
It seems like I have the same problem as mike did with his boat. the gelcoat with wax did not cure fully and is still tacky. Do I need to add another coat or can I spray some PVA over it or is it too late for that now. I had about 1.5% wax added and shook the bottle too. the temp was well in the 70s.
Woodonglass
Did you put wax only in the last coat of gelcoat?
PVA must be applied within 30 minutes of the last coat. After that it's not gunna do much good. Get it in the sun and or get some heat lamps on it but i'm skeptical it will harden. You'll probably need to remove and start over.
Chris51280
Ensign
I did mix 2% MEKP and 1.5%Wax. The Wax I mixed in the can. I added the MEKP last in the mix. I can get it in the sun. I currently is in a barn and needs to come out anyways for engine install. It is slightly tacky not like it is when you would apply it without wax. It may still cure? Can I paint another layer over it with PVA on top then as last resort?
AShipShow
was the wax seperated? The surfacing wax is dissolved in styrene but if its now warm <75° or 80° it tends to separate out of the styrene.. You need to slightly heat it before shaking and adding to the gelcoat. You might have been okay with your temps, but just a thought on what the issue could be.
Just an FYI, ive found the best way to heat the wax is to put the bottle in a cup of hot faucet water for 10 or 15 minutes. When you can't see any cloudy/white solids in the bottle, you know its dissolved in the styrene.
Chris51280
Ensign
I will try to get it out in the open and if that doesn't help, then I will paint it again with a bit more wax and shaken up. And add PVA. That should then do the trick
Chris51280
Ensign
So i applied another layer. I'm out of pigments now too. I sprayed pva on within 10-20min. Is it normal that it takes awhile to dry with the pva? I did a good 2% of wax on it and 2% mekp. Today was 75F. Hope it works now
Woodonglass
After the PVA is applied you should be able to wash it off in a few hours. You'll need to wait a few days before doing and wet sanding.
You either use surfacing wax or PVA NOT both.
Chris51280
Ensign
When I installed the bellows, why are the metal clips on there? Wouldn't that give a chance for not completely seal and water getting inside the drive bellow?
There is no current flowing through the rubber bellow to be of any purpose. Is is to grab onto the ring? It seems to be more of a pain to get them oriented right along with the whole installation process. Need like 3 hands.
Mechanicalmike08
To ground the clamps, they are a pain.
Mine was fine after a day in the sun, But I know I had a problem with separated wax. Mine still felt soft for the first day or so but once i got it out in the sun everything hardened up real nice.
Chris51280
Ensign
Outdrive is ready to accept the engine. Test fitted the cluster and coutout the old dash.
the gelcoat cured in a couple of spots but appears still soft in others. I will likely e with it for now. Maybe it will still cure enough
Chris51280
Ensign
Pulled the boat out onto rhe trailer. Ready for some horses.
the trailer got a new roller and new bunks.
the rear bunks were moved 12 inches forward. They are now perfectly even with the transom
Chris51280
Ensign
Continued with the install. Steering ram attached. Speed sensor installed, chair mounted. Ski locker hatch installed. Measurement of the side panels.
