Hi,
I've poured through the forums and done the diagnostic test which, so far, point to needing a new ICM. I am still in denial due to the cost of those things! So here is my story.
Went out for a ride one day and the engine seemed to want to stall. if I pumped the throttle it would stay running. Eventually it just plain died and we had to get towed in. After checking some things i am now going down the ignition path even though it appeared like fuel before. There could still be a fuel problem but i discovered the coil wire was open and the coil itself was bad (no resistance). The top connector of the coil was all black and ugly. So...I replaced those (Sierra parts) and still no spark on coil wire. I then found the very nice diagnostic diagram on this forum for the Thunderbolt V ignition. Here are my findings.
Tachometer not grounded - ok... so i tried unplugging the connector at the back of the tach and disconnecting the single gray wire from the coil. Is there another way to do this step?
with Key in Run position check for 12 V at Coil - I have 12 v
Unplug white/red and check for 12 v from module - I have 10.5 volts, not 12 <- is this an issue?
Spark test at coil with white/green quickly against ground - no spark
so with the above results and a new coil + coil wire does this positively point to the $600 ICM Module?
Mercruiser Model MCM 4.3L 262 CID sn 0M685713
Thunderbolt V
Distributor cap/rotor kit 815407Q Sierra 18-5396 <- not installed yet
Coil 8M0079202 Sierra 18-5438 <- installed
Wire Kit 816761Q16 <- installed only coil wire, others "look" ok
ICM Module 861252T1 <- hoping to not have to purchase
Thunderbolt V
