I have a 2002 Stingray 240 CS with a Mercruiser 5.0 MPI I/O (Mercruiser S/N: 0M347458). When I started the boat this season, it fired up and ran for a few minutes, then died. Now, when I turn the key in the ignition to the "Run" position (without trying to actually start the engine), the ignition alarm doesn't do its test beep like normal, and I don't hear the fuel pump run (normally it runs for a few seconds, I assume to prime). After about 20 seconds, the ignition alarm sounds steady on, and the fuel pump runs continuously. If I cut off the safety/lanyard switch, the fuel pump stops, but the alarm continues. The engine will turn over if I try and start it, but it won't actually start. On the gauges, I get battery voltage, but the oil pressure gauge remains at 0 (although I do see the needle move a tiny bit when I first turn the key). I checked the main cannon plug, and it passes a quick visual inspection (although it was really difficult to remove).
Any thoughts? Thanks!
