your exhaust elbows will only last about 5 years. your manifolds may last 10. the block and heads with proper maintenance will last another 20-30 as Chris stated
however every few years you need to pull the elbows and inspect. when the elbows go, they leak water into the motor which kills the motor.
also, your impeller wont last as long in salt.
