achris
More fish than mountain goat
- May 19, 2004
- 27,468
Just finished putting together a 350Mag MPI after it filled 4 cylinders with seawater. Turned out to be a cracked exhaust manifold (after the owner didn't notice/ignored an overheat alarm). The engine got the full treatment - new pistons, bearings, lifters, pushrods, etc. I took a couple of days putting all the fruit back on and checking everything was good. I spun it over without spark plugs until the computer showed I had oil pressure, then in with the plugs, and connect a fuel tank... Let's see if it runs... (unable to throttle it up because...DTS...)
Chris........
EDIT: the 4% power available Guardian is due to the ECU failing to detect the throttle and shift controller, 'Canbus error'. When it goes back in the boat and the DTS cable is reconnected that will return to 100%
Chris........
