Delco EST Distributor
wufibugs
I have a Delco EST distributor that has two plugs. Left plug harness goes to the ignition coil. Right plug/harness has 4 wires. There is a special 3 wire harness for engine timing. On this plug, wires 1 & 2 are jumped together; wire 3 is connected to 12v. The 4th wire goes to the shift interrupter. The regular plug has only the 1 wire that goes to the shift interrupter.
I am not sure if the wire that goes to the shift interrupter is the leftmost or rightmost of the 4 wires. Any help you can provide is appreciated.
Richard
achris
More fish than mountain goat
What engine are you working on? (Year, model and serial number)
Chris....
achris
Richard
The plugs are 'keyed', you can't get it wrong... But the white/green wire from the right hand plug is on the left of that plug (nearest the other plug)...
Chris.....
